ideas on juicin up my 1litre to give bit more shoe??
dolly4mini
What Minis have you?: city
Modifications: sparco bucket seats
Post by dolly4mini »
i have an 89 mini city lil mint lookin beast..silver with purple roof n purple racin stripes..wud break my heart ta sell it as it was my first car..so came to the conclusion of sellin up and boostin up the mini..any ideas how big and expensive its goona be?? :?: :)
Re: ideas on juicin up my 1litre to give bit more shoe??
That sounds a familiar mini. Where are you from? Would we have seen it around somewhere?
Miniman
Whats your location?: Cavan
What Minis have you?: 1966 850,92 city,98 2.5turbo R33 Nissan Skyline and a 1979 Mini Clubman
Modifications: To many to list!
Post by Miniman »
Stick a vtec engine in it :mrgreen:
Bending the rules,and ruling the bends,Since 1959!
How much do you want to spend ?
Titanium hubs only cost £1195 a pair. :shock: :lol: :roll:
The Marcos Graveyard wrote:How much do you want to spend ?
only!?!?!
Sorry but I am lost :roll: what are you asking ? Do you intend to sell it ,or power up the motor? :|
sanguiss
Post by sanguiss »
As far as i know the bolt on modifications you can do on the 1 litre engine are: stage 1 exhaust, LCB and K&N filter (20% power increase), and changing the cylinder head with a ported and better flowed 12g295 from a 998 cooper s (+6 hp). This without spending too much money. If you can and want to spend more then you can:
put a lightened timing gear, flywheel and clutch
change the camshaft, megadyne 256 or 266, these woul give you better torque at low and mid range rpm's respectively, don't go for anything higher than 270, you won't get any benefit unless you are always pushing the engine higher than 6000 rpm.
As far as i read there is no advantage really in changing the rockers with 1.3:1 high lift, again unless you re pushing the engine all the time over 6000 rpm.
You can install a ram pipe to increase air flow in the carb, but the gains are a max of 4-6 hp, according to the golden pages Vizard manual.
Then you can go for +40 or +60 omega pistons, but at this stage you are redoing the whole engine.
Or you can simply put in a 1275 engine.
Now let's see how much the experts will kick my ass :-)
i really didnt write this very well:
*edit*
IMHO on a 998 i'd put on a stage one kit, which bolts on as sanguiss says and makes for a lovely drivable car with plenty of poke. costs about 150.
if you want even more power, go for an engine swap. pretty much get what you pay for.
When 6 of us drove our Minis to Holland for IMM2008, at least 4 were 1-litres, including KMG's automatic and we held our own on the motorways.
And before the slagging starts, if I had a big thirsty 1275, I'd have run out of petrol much sooner!
zakgt
Whats your location?: Maynooth
What Minis have you?: 1962 - Morris Traveller MK1 - 1978 - 1275GT, 1998 - Sportspack
Post by zakgt »
Billy,
To be fair,woody had a crap 1275 engine and the 1 litres felt the hills across England, not many hills in Holland though.
dolly4mini
tanx every1...tinkin bout it bigtime now...am in laois bt car has been off the road 4 last year snapped accelerator cable and mechanic has no intentions of fixin it :(
that usually a fairly easy fix....
just_st3v3n
Post by just_st3v3n »
that is an easy fix....
1. undo the cable at the accelerator pedal, its located right at the top of the pedal and should just slide up .... (bend down awkwardly to find it)
2. undo the accelerator cable on the carburettor (its only one of two, one is the choke the which is at the back, accelerator is at the front)
3. once the accelerator cable is undone on both ends follow where the casing goes and remember , then pull the casing not the cable, and then pull the cable from inside the car et voila!
4. ya could order a proper accelerator cable or be a cheapy like me and get an ordinary bicycle brake cable which does the job the same, you'l have to cut the cable and the casing (bicycle one) and do the exact opposite to the way you got it out :)
hope that helps.. its really not a hard job to do, and anyway its broke already so ya cant do anymore damage anyway while giving it a try :roll:
some day....
dolly4mini
cheers...dont kno if ill hav the funds anymore...anyone interested in buyin??
Stick an ad up in the For sale section and see how you get on
