PROBLEM
PROBLEM
was driving earlier and when i went to indicate i got nothing.no.click,light or any sighn of it trying.any1 know wat it could be? my nct got reshceduelled to tonite so need to get this sorted asap.
karl
karl
- just_st3v3n
- DaveC
Re: PROBLEM
Check the flasher unit as well
Re: PROBLEM
the cars a 84 city. replaced all fuses.im getting no reaction from the stalk at all no flicks or anything.was working perfectly untill yesterday.
- CLUBMANGT
Re: PROBLEM
Pull the flasher relay its under the dash its normally a round unit and stick it back in it may be stuck
Re: PROBLEM
take out the hazard light switch and disconnect the plug from the back of it ,also as said check the relay ,it should be on the right hand side of the bulkhead under the bonnet a round silver unit stuck into a plastic holder....
Re: PROBLEM
checked relay there.seemed ok.would the stalk be faulty?
- StanO'Toole
1994 Mini Sprite - Contact:
Re: PROBLEM
I couldn't see your stalk just stop working. I would have thought that it would be faulty before it just completely stopped working but maybe. I remember a few weeks ago Glennons M.P.I's indicators and brake lights went and it was down to a fuse in a fuse box.
Re: PROBLEM
spent an hour cleaning fuses and connections and checking everything over.would the indicaters stay on or would there be no light at all if the relay was faulty?
Re: PROBLEM
not necessarily have you tried a different flasher unit and also did you disconnect the plug from the back of the hazard switch and try the indicators againkarl wrote:spent an hour cleaning fuses and connections and checking everything over.would the indicaters stay on or would there be no light at all if the relay was faulty?
Re: PROBLEM
ye took the hazzard plug out and cleaned the relay points.still nothing
Users browsing this forum: No registered users and 22 guests
