Anyone removed GB from their Mini's rear?
Hi people,
Just looking to know if anyone has any experience removing the GB letters from the rear of their Mini?
How are these attached? and do they leave behind a mark?
Thanks in advance,
Chris
(I've a 97 Cooper)
Thanks in advance,
Chris
(I've a 97 Cooper)
- What Minis have you?: 00 Cooper S
Re: Anyone removed GB from their Mini's rear?
talk to al the mod, he'll tell ya why not to do. I'm sure his first tip will be, don't think rain will make it come off cleanly... It doesn't. HaChris wrote:Hi people,
Thanks in advance,
Chris
(I've a 97 Cooper)
- antodeco
From previous experience removing badges off cars (not minis!) they are stuck down with glue. Some dental flow behind it and you should be able to "saw" the glue out. You can put a hairdryer to it to heat it up if you want, but you can damage the paint.
- Whats your location?: Carnone near Raphoe
- What Minis have you?: following the rest
1977 Mini Clubman Automatic
1974 VW Beetle 1200
1982 VW Mk1 Golf Convertible
2008 VW Golf 1.9tdi - Location: Co. Donegal
I removed them of mini, there were on with the double sided foam, pop'd mine off carefully then removed the excess with a bit of petrol and there was no mark left
William Whyte
- antodeco
Depending on the finish of the car, becareful with petrol. Did it to an old micra before. Left a weird stain on the paint.
Thanks guys!
So far it's not looking like it'll be much hassle to remove, the colour's british racing green.
give it the hairdryer treatment and it should just pop straight off!
it will leave a small bit of residue, but nothing a good cloth and some elbow grease cant handle!
mine have threaded studs on the back ,check inside your bootlid to see if theres nuts on the back before you go trying to prise them off ,there might be 4 holes left if you do remove them ,or you could do what i did and just reverse them BG....
- coop
- Whats your location?: Wexford
- What Minis have you?: miniless
If they are factory fitted like mine were, they are just stuck on with a black sticky foam that can be gently pulled off, any residue can be washed off. Are ya worried about vandalism?, thats why mine are gone
had GB on my clubman and got them off with the aid of a heat gun
but on low heat go gentle and slow as to much heat can bubble
the paint so slowly does it
as done right is better than a trip to paint shop
regards deco
regards deco
have ur IRL sticker ready.
- miniroar
- Whats your location?: if I had a garage probably in there!
- What Minis have you?: 1990 BRG and 1972 Saloon
- Modifications: Roll cage,custom dash/smiths gauges, Sony xplod ICE 15" sub boot build, 6 x 9's under rear seat,13cm dash, amp built into parcel shelf, Blue angel eyes,neons, MR2 seats, zeemax kit, superlights 13 x 7
I had them on my brg mini aswell my aul fella took them off no marks left I'll ask him how when I see him
