problem that i want to fix
Posted: Fri Jan 01, 2010 10:13 pm
by cooper7
looking for an answer to this problem please.how do u stop damp or wet as if u had a hole in the roof appearing on the head cloth.is it just condensation? .thanks
Re: problem that i want to fix
Posted: Fri Jan 01, 2010 11:35 pm
by gareth
Move to california........
Joys of mini really. Its condensation caused from damp in the car. You can make it better by trying to let less damp in the car. As in replace any door or window rubbers that are cracked old or not sealing well.
Posted: Sat Jan 02, 2010 12:49 am
by StanO'Toole
Like Gareth said replace any cracked / damaged seals around your window and if you get a demistifier it will also help
Posted: Sat Jan 02, 2010 8:31 pm
by cooper7
cheers for the answer would luv to move to LA
Posted: Sat Jan 02, 2010 10:06 pm
by seanos
moisture mate!
or silica sachets, when you buy electrical good, or anything boxed, they come in them.
keep them and lash then in your car on the dash or back seat, they absorb any moisture.
or
put a bowl of salt in your car when your not driving, that absorbs moister, but don't forget to take it out before you drive
