Emission fail
- Tinkerbell
- Whats your location?: Enniskerry, Wicklow
coming from: Cologne - What Minis have you?: 99 Cooper, Tahiti Blue, Old English White roof
Emission fail
Hi to all,
as mentioned in the "Seen a Mini" thread my Belle Blue failed the NCT because of the exhaust emissions.
The readings are
Temperature: 83 °C
Low Idle (900 rpm): CO 2.20 vol% - HC 0 ppm
Lambda: 1.049
High Idle (2810 rpm): CO 1.77 vol% - HC 163 ppm
A colleague of mine told me to use Dipetane to get around the prob. But as he has a Peugot (and he is French ) I do not really trust him. Just joking.
The tester said there could be something wrong with the catalysator.
Please help,
Tinkerbell
PS: I read the NCT Emissions thread, but I am not a technical person.
The readings are
Temperature: 83 °C
Lambda: 1.049
Please help,
Tinkerbell
- BERT
Re: Emission fail
Hey il have a look some evening if ur stuck,only in greystones,Bert 0858445677
Re: Emission fail
When was the last time you changed the plugs/oil/oil filter/air filter?
It probably needs a service. Putting stuff in the petrol isnt the way to go. 95% of the time High emissions means that there is something wrong with the engine. The otehr 5% its ment to have high emissions.
- Merlin
Re: Emission fail
what year is the car ?
Re: Emission fail
It is a 99 MPI Paul.picture of it on page 22 of "Seen a Mini"thread.
- Merlin
Re: Emission fail
that lambda reading sugests it is running lean I would doubt the cat is your problem,
Re: Emission fail
Is that the high idle for mpi cars too? seems abit high.
- Tinkerbell
Re: Emission fail
Hi guys and gals,
I bought her in June this year from a young lad on the Northside.
He told me he just changed the plugs/oil/oil filter/air filter before he had put the ad on the web and hasn't it driven since (about half a year beforehand).
I had a look on the plugs and the airfilter and they seem pretty new to me.
@ Bert: Thank you for the offer I will call you.
