spi mini
Posted: Tue Dec 08, 2009 7:08 pm
by cbyrne
hi i have a spi mini can any one telll me who knows alot about them im looking for more power and am NOT going back to carb!!!
Re: spi mini
Posted: Tue Dec 08, 2009 7:17 pm
by swalker
First port of call would be the cam the std is so crap bolt in mods are pointless.
Re: spi mini
Posted: Tue Dec 08, 2009 7:30 pm
by cbyrne
where would i go for that?? i no the kent 274sp is the most severe for the spi but its pricey!!
Re: spi mini
Posted: Tue Dec 08, 2009 11:10 pm
"NOT going back to carb!!!
This would sugest you are looking for reliablity so I would ask how far you want to strip the engine down?
If you are looking for bolt on mods then leave the cam, buy the best head you can afford and add high lift rockers. Then look at adding a decent exhaust system and manifold and maybe a larger throtle body.Don't forget it still needs to pass the NCT.
Re: spi mini
Posted: Wed Dec 09, 2009 1:17 am
by kona
Apparantley the SPI ECU is the limiting factor, it cant fuel a 100bhp engine right. So much easier and cheaper to get a 100bhp carb mini. Also if yours is a 1995/6 car, you are going to find it almost impossible to pass emissions tests with a decent cam.
Id Imagine the best mod for SPI would be to fit a better head and higher ratio rockers. Then get the cam done when you decide on how to fuel it.
Re: spi mini
Posted: Wed Dec 09, 2009 10:27 am
by swalker
whats the limit on the emmisions down there?
the sw5 cam seems to be the one up here for the spi. This passes the mot coming in below the 3.5% limit.
My knowledge on this subject has been picked up through other forums, but there always is a common answer, ditch the cam before doing anything else.
The spi ecu probably cant fuel a 100bhp, but i dont think ther every was one of these made!
Was the last cooper not only 80 odd? and this would have been mpi.
if you want 100bhp from a carb you are talking 45 dcoe and 1400cc.
call me a mini snob but I only realy like them in 10's!
Re: spi mini
Posted: Wed Dec 09, 2009 11:48 am
I would presume the limiting factor of an ECU injection system would be how long the ECU can open the injector so would fitting a larger injector not give you more power?
Re: spi mini
Posted: Wed Dec 09, 2009 12:23 pm
by swalker
The fuel delivered to the engine is controlled by the ecu, but it gets feed back from other sensors to determine duration and timing.
This is where getting it chipped comes in.
If you want more fuel you need more air and that's where the cam comes in.
Does that make sense?
Re: spi mini
Posted: Wed Dec 09, 2009 2:31 pm
by kona
I think some german lads made a chip for the SPI, yer man keith calver said hed supply it for the UK.
The emissions down here is 3.5 co and 750PPM for SPI.
Would more air not come from a bigger throttle body/carb? whereas the cam and head, just dictates how much air/fuel you can get into the cylinder via opening the valves to a given duration?
Id Imagine on Spi you can get the cylinders to fill, but not the correct fuelling, especially up at the top end, which will cause it to run crap? Im sure you could buy another ECU for the fuelling however.
What type of power are you looking for? Merlin here would be a good man to talk to about how to go about it?
My first mods would be a bigger throttle body and a properly worked head alond with some 1.5 rockers. Then go from there. If your replacing the cam you may aswell do a full rebuild. Also It mite be worth looking at the gear ratios.
Re: spi mini
Posted: Wed Dec 09, 2009 2:52 pm
Monty was chatting about this with myself and BlackSe7en at the IMM in Poland, he was saying that when the Japanese are tuning the Spi/Mpi, the first thing they do is ditch the ECU.
Re: spi mini
Posted: Wed Dec 09, 2009 3:22 pm
by kona
The Marcos Graveyard wrote:Monty was chatting about this with myself and BlackSe7en at the IMM in Poland, he was saying that when the Japanese are tuning the Spi/Mpi, the first thing they do is ditch the ECU.
What ECU do they put in? I thought there wasnt really anything you could do. Still, The emissions are going to be a serious pain.
Whats the points in spending a couple grand to gain 20-30bhp?
Re: spi mini
Posted: Wed Dec 09, 2009 9:29 pm
by cbyrne
ok iv found a carb engine k series 1.4 8v so its spi out carb in and when nct comes spi back in. how can you tune a carb engine??
Re: spi mini
Posted: Wed Dec 09, 2009 10:21 pm
by swalker
This will sound stupid but its always over looked. Set it up right first.
Dizzy then carb.
Re: spi mini
Posted: Wed Dec 09, 2009 10:26 pm
by kona
Does the K-series have a carb version? I didnt think it did?
Re: spi mini
Posted: Wed Dec 09, 2009 11:26 pm
by BlackSe7en
[quote="The Marcos Graveyard"]Monty was chatting about this with myself and BlackSe7en at the IMM in Poland, he was saying that when the Japanese are tuning the Spi/Mpi, the first thing they do is ditch the ECU.[/quote]
Either I was asleep or having a pint of Polish beer
Maybe this is what you need:
http://www.miniworld.co.uk/video/Specia ... 92775.html
Re: spi mini
Posted: Fri Dec 18, 2009 7:22 pm
by cbyrne
haha i want how much woult that cost??
Re: spi mini
Posted: Sat Dec 19, 2009 1:15 pm
Specialist Components do the engine for about £7000.
http://www.specialist-components.co.uk
