metro engine
rhys mate
What Minis have you?: mini city
Modifications: metro engine
metro engine
Post by rhys mate »
just wondering how to determine the year of my engine it a a 1275 metro engine. and are the subframes any different or do they slot straight in??
also what kind of power do they usually put out im getting mine dyno tested tomorrow and want to know if its normal or not.
cheers
Everyday is a mini Adventure
Re: metro engine
The metro engine will be an a+ engine so 80s on in age but , the metro subframe is different and wont go near a mini shell
if that is what you are asking :P
Re: metro engine
Post up the engine number and we may be able to help.
just_st3v3n
Re: metro engine
Post by just_st3v3n »
the 1275a+ metro's put out 72bhp standard, whether thats at the flywheel or not i dont know..
put up the engine numbers and you;l be able to find out who n what..
some day....
rhys mate
Re: metro engine
Post by rhys mate »
i managed 62 today but it was running very very rich so im expecting more the next time does anyone know how to tweak the HIF needle?? i cant find the adjustment at all
Re: metro engine
You need to change the profile of the needle to "tweek" it.
The mixture adjustment is on the side of the carb.
Re: metro engine
1275 A+ metro engines range from low compression metro vans to MG Metro Turbos with many inbetween. The first part of the engine number gives you the spec.
Re: metro engine
post that engine number already.. or if it a block like mine, the little plate has "rusted and fallen off, officer.. honest..."
pn951
Whats your location?: Cork
What Minis have you?: 1979 Van
1979 Pick-Up
1990 RSP Cooper
1991 Lamm Convertible
1992 Mayfair
Modifications: Rust Rust Rust. Oh sorry thats not a mod, thats standard...
Re: metro engine
Post by pn951 »
Just as a matter of interest, where did you get it dyno tested? What sort of cost is involved?
Re: metro engine
Sounds like you need a go of the old gas meter mate :roll:
rhys mate
Re: metro engine
Post by rhys mate »
ill put up the number later haha :mrgreen:
i got it done in CIT for free we had a Twin-cam and a type-r too!! some noise off the Civic.....
he said take it back after i find out how to change the mixture and see waht we get!!!
Re: metro engine
The mixture screw is number 7 in the photo.
This is used to adjust the mixture at idle, the needle profile then determines the mixture further up the rev range.
rhys mate
Re: metro engine
Post by rhys mate »
thanks a million for the help! any ideas on which needle i should go for??
i got ny engine number 12H009157760!
Re: metro engine
rhys mate wrote:thanks a million for the help! any ideas on which needle i should go for??
thats not coming through as an engine number... 12H makes it a 1275, but after that,... can you verify that number?
rhys mate
Re: metro engine
Post by rhys mate »
ill double check with the number on the block thats what the log book says :?
rhys mate
Re: metro engine
Post by rhys mate »
i checked the engine number its no different to the one on the log book?? im confused!!
Re: metro engine
id doesn't seem to be a mini engine, it might be a metro unit, or an allegro/maestro/other BL car. the "12H" makes it a 1275 transverse, prior to 1990, but you already figured that out!
see: http://members.home.nl/mmarx/mini/metronmbrs.htm
most likely so far is this: 12HD09 9.75 : 1 1989 1.3 Metro Saloon
miniireland
Re: metro engine
Post by miniireland »
more than likely an early metro 1.3 hle
http://www.ime.org.uk/ime/e/BMC_MG_&_Mo ... _Codes.pdf
Metro 1300 HLE 1275cc 12HA08AA
.. .. 1275cc 12HB, 12HC, 12HD, 12HE,
12HF.
MG Metro 1300 leaded fuel pre 1989 1275cc 12H996AA, 12HD24
MG Metro 1300 unleaded post mid-1989 1275cc 12HF01
MG Metro Turbo leaded fuel pre 1989 1275cc 12HD26
MG Metro Turbo unleaded 1275cc 12HF01
Austin Metro Sport .. 1275cc 12HF02
Austin Metro GTa .. 1275cc 12HF02
Austin Metro's with unleaded engines, 1275cc 12HE24, 35, 39, 40, 41,
42, 67 up to 75.
rhys mate
Re: metro engine
Post by rhys mate »
nice one thanks for all the help!! just need to figure out the needle profile now haha!! he thought the needle could do with being smaller or the carb being the original to sort the performance out!!
Re: metro engine
rhys mate wrote:just need to figure out the needle profile now haha!! he thought the needle could do with being smaller
:shock: :shock: :shock:
The needle is tapered, It's the shape of it that alters the setting not the size of it.
There is a 3 letter code on the needle, which one are you running ?
Re: metro engine
Engine No 12HD09,
I Found a listing of it as Mini 84-86 ,Austin 1.3L and 1.3 HLE.
To the best of my Knowlodge ther was no 1275 Mini 84-86 and I presume the Austin is referance to the Metro 1.3L and 1.3 HLE.
Dizzy number should be 42626
Re: metro engine
hle is defo a metro...
rhys mate
Re: metro engine
Post by rhys mate »
had a go off the carb the last day to try sort the mixture but when i did i noticed the choke had been adjusted to run all the time so i slackened it off and tweaked the screws a bit to get the revs up but the car kept hunting and cutting out!! it also got 11.5% Co2 in the nct so failed badly!! i wqs told to get a new needle and jet assembly so what profile needle would be best1!! must check the needle i have now!! its a 1275 metro im pretty sure its got a hif38 carb!!
thanks
Re: metro engine
is there a metal strip screwed to the carb body someplace with letters & numbers on it? usually three letters and four numbers. what does it say?
no matter *what* needle is fitted, it should be possible to get it to idle cleanly.
at bottom left hand side of the carb, as seen from the front of the engine, there is the recessed idle mixture adjustment screw. with the engine warmed up, timing correclty set and the choke fully in, turn the screw to get the smoothest idle.
i have an MG metro engine in my mini clubman, and the carb is HIF44.
rhys mate
Re: metro engine
Post by rhys mate »
keith wrote:is there a metal strip screwed to the carb body someplace with letters & numbers on it? usually three letters and four numbers. what does it say?
thats the screw i was turning but i was finding it impossible to get it to idle!! which way do you screw it to reduce the mixture??
i got 11.53% vol and 2210 ppm!!! not good :lol:
cheers keith
