Hi all
Im having a bit of a problem with my front lights,
The rear right lights work, left dont, and all indicators work, just the front heads, dims and parks wont work.
When I turn the them on, the dash lights all work fine, but the blue light on the dash indicating high beam stays on whether I turn the high beam on or off.
The thing is the main beam lights do work if I flash them with the headlights switched off, just when I turn the headlights on nothing works.
The 4 fuses under the bonnet are all fine.
Im just wondering has anybody seen this before and maybe able to point me in the right direction??
Thanks in advance
Jonesy
Front lights problem
- Whats your location?: celbridge co kildare
- What Minis have you?: 92 city and 83 leyland 1000
- Modifications: zeemax kit 1330 engine
Re: Front lights problem
this happened to me awhile ago theirs an inline fuse beside the carb(dont know weather it was just on my car) changed the fuse and mine worked for a while mine ended up being the bottom fuse holder itself and paul kelly bypassed it with an inline fuse
Sounds like you are missing the main earth on the front lights. Check the bullet connectors at the top of the grill.
woody wrote:Sounds like you are missing the main earth on the front lights. Check the bullet connectors at the top of the grillyellowminiman wrote:this happened to me awhile ago theirs an inline fuse beside the carb(dont know weather it was just on my car) changed the fuse and mine worked for a while mine ended up being the bottom fuse holder itself and paul kelly bypassed it with an inline fuse
Cheers lads
Will get a look tomorrow and hopefully get it sorted out
Jonesy
Thanks very much for the replys guys
Bad earth connection behind the grill....
Always easy when u know where to start looking
Jonesy
