Hilos
- coop
- Whats your location?: Wexford
- What Minis have you?: miniless
Hilos
I am trying to adjust the rear hilos but the adjustable spanner just wont fit, so what size spanner do I need for the adjustment nut. Is it a 28mm?, they are the minispares cheapo Hilos.
Re: Hilos
Just measure it with a tape or vernier.
- just_st3v3n
- coop
Re: Hilos
It drives just like it did with rubber cones, except bumps and potholes are less harsh. With the shocks on their softest theres lots of suspension movement, the exhaust hanger actually scrapes on the ground when going round right hand turns even with a ride height of 60mmD_3m0_n wrote:OFF TOPIC
springs!!!![]()
wats the drive like with them on??
Re: Hilos
I have minispares HI LOWS on my car and the spanner size is 30 mm you need two
and it aint easy yo do
Re: Hilos
Just use a large adjustable. That's what I did when I put HiLos on mine.
'90 Mini City - No More!
- coop
Re: Hilos
TONY R wrote:I have minispares HI LOWS on my car and the spanner size is 30 mm you need two
Thanks for that, I got a 30mm spanner and a less bulky adjustable spanner and managed to do it although it took agescity998 wrote:Just use a large adjustable. That's what I did when I put HiLos on mine.
