Non Project: My Mini
Buddy
Post by Buddy »
Thought id better post up some pics of my mini as i dont think i ever have on thsi site!
anyhoo here she is, had her 2 years so far and am saving at the moment for a big engine!!!
Re: Non Project: My Mini
Where did you take those pictures? I was down that back laneway behind Laservison today and it looks like you haven't move the Mini since the last time I was there :wink:
The Green "TS" Mini doesn't like it has moved either.
Buddy
Post by Buddy »
i took the pictures last Saturday after a run with a few lads from miniresource in bray!
i don't use the car on weekdays as i walk to work!
did you spot my lovely oil leak!
It wouldn't be a Mini without an oil leak. :lol:
Buddy
Post by Buddy »
ive had a quite a bad leak since i put some oil in last week, i think i may have actually too much oil in her tbh
would that cause a leak?
What oil did you use ?
Thats a lovely looking Mini there, Buddy :)
Interesting to see the high reg number. I don't expect we will be seeing such a huge record of new cars being registered in one year in the near future.
Funnily enough, regarding oil leaks.... Having a Princess and a Dolomite already I'm used to the odd seep of oil from time to time BUT since the Mini arrived it's not shed so much as a drop of oil :D
If you did put too much oil in, it would potentially cause a seal to blow.
Perhaps drain some out, ensure engine is cooled down and dip the level. When refilling, pour small amounts in at a time, allow to settle and then dip again.
Might be no harm to drain it all out and replace the oil filter also.
Process of elimination etc :)
Tony.
PS-don't hang about attending to that surface rust on your front/rear valances and door bottoms. Prevention is always better than cure!
Buddy
Post by Buddy »
[quote="The Marcos Graveyard"]What oil did you use ?[/quote]
millers classic sport 20/50
same as i always use!
Buddy
Post by Buddy »
Coonos Cab wrote:Thats a lovely looking Mini there, Buddy :)
Tony.
thanks for all the advice!
i think ts the seal at the gear selector thats is gone as it had leaked before but hasnt leaked in a while until recently
as for the doors, theyll be attended to eventually, im gonna try get either new skins or maybe entire new doors eventually i reckon, the drovers door is quite badly rusted on the bottom and beyond salvaging im reckoning
INNY1300
Post by INNY1300 »
Hello Buddy nice looking mini look forward to seeing the mini at an event,regard's jon :twisted:
by any chance are you up around the clondalkin/newlands cross area? i think i spotted you!!!
Buddy
Post by Buddy »
[quote="glennon"]by any chance are you up around the clondalkin/newlands cross area? i think i spotted you!!![/quote]
dont live there but a friend does, i visit quite regularly!
have the car down with albert in delgany at the moment
getting the gear selector leak fixes, poly bushes into the engine, steering column drop bracket fitted, fog light fixed and a new gasket for the rocker cover
the engine mounting bolt has snapped into the engine so the bolt eill need to be replaced and the hole rebored i think, seems like a big job but glad im getting it sorted, heard good thing about his work so happy enough!
The easiest way to get the sheared bolt out of the side of the block is to drill a hole in the bolt and hammer a suitably sized torx bit into the hole, then unscrew with a ratchet. It's worked for me on a few occasions.
Buddy
Post by Buddy »
was talking to albert this morning and he said he'll be able to get it sorted so ive left it in his capable hands!
once this is all done there should be nothing wrong with the car whatsoever! i think for the first time in years!
it should be worth it!
TWINcarbs
Post by TWINcarbs »
nice looking mini man!
many years luck!!
aaron
Buddy
Post by Buddy »
Got my new removable steering wheel installed!
Looks nice and neat, is it much closer to you than the standard ?
Buddy
Post by Buddy »
close but not too close!
at least now i can see all the dials when driving!
one thing tho, my indicators aren't self cancelling, is that cos i may have not put the plastic part that cancels them in right again? its only s minor inconvenience but the wheel isnt on exactly straight so ill have to re-allign it again anyway so may try and sort out the indicators while im at it
wheel may look closer as i got a drop bracket installed aswell, much better driving position!
i really need to stop spending money on it, but ive got so much more planned!
madjackjr
Post by madjackjr »
Same thing happened to me with my steering wheel. The boss doesn’t have a piece that sticks out and cancels the indicators. But as you say its minor inconvenience and after a short while it will become second nature for ya to turn it off :D
madjackjr
Post by madjackjr »
Oh ya a mini is never a non project :P :D
Would it be possible to drill a suitable hole and fit a roll pin to operate the indicators ?
madjackjr
Post by madjackjr »
Come to think of it ya you could, on my boss it's a solid plate at the back but I wouldn't bother I’m used to it at this stage unless it was some kind of stupid NCT failure :shock:
Buddy
Post by Buddy »
my new console...
Buddy wrote:i took the pictures last Saturday after a run with a few lads from miniresource in bray!
*Ahem* :P :D
Buddy
Post by Buddy »
*Ahem* :P :D
hahah apologies, i mean macker took the pictures after a run!!
