Moderators: spud1979 , The Marcos Graveyard , Moderators
karl
Posts: 39 Joined: Sat May 10, 2008 9:04 pm
Post
by karl » Sat Dec 06, 2008 3:12 pm
was out in the garage last night cleaning my classics engine with a bit of degreaser and water,i was carefull of the electrics.but when i went to start it up it started to splutter and will not idle
.im quite new to minis so would apprieciate any help whatsoever.
thanks,
karl.
Posts: 2118 Joined: Tue Jul 18, 2006 11:15 pm
Post
by keith » Sat Dec 06, 2008 5:52 pm
two probable options here...
1) you dislodged a hose or vacuum pipe.
or
2) you did in fact wet something.
my money is with the dislodged pipe.... wet electrics tend not to start at all.
do say if its an injection or carb mini although the options above are valid for both.
Posts: 4653 Joined: Mon May 09, 2005 12:49 pm
Post
by Billy » Sat Dec 06, 2008 6:33 pm
Another possibility is that you soaked the air filter. I've seen it happen (albeit on my Honda 50) and when I took off the filter it ran fine.
Whereabouts are you based? Maybe there's a club member living nearby?
Posts: 2837 Joined: Mon Feb 07, 2005 11:55 pm
What Minis have you?: Traveller Turbo Hornet Equinox MINI Clubman
Post
by woody » Sun Dec 07, 2008 10:53 pm
What year car or engine.
karl
Post
by karl » Mon Dec 08, 2008 11:13 pm
thanks got a new set of plugs in this morning and she fired right up.
Post
by Billy » Mon Dec 08, 2008 11:16 pm
Glad to hear you got sorted. These problems are usually quite minor but are usually the cause of much headscratching.
Post
by keith » Tue Dec 09, 2008 2:44 am
sometimes the simplest solutions are best!
