Battery over charging
Posted: Thu Oct 02, 2008 7:55 pm
by joebe1
I have found the gt to be over charging the battery, anyone who remembars adrains gt will remember the terrible smell from the battery, this is why, just wondering what the correct voltage the battery should be charging at without any load eg lights etc think it somethin like 14.3 volts but not sure. Am thinking the cure would be a new voltage regulator?????????????
Re: Battery over charging
Posted: Thu Oct 02, 2008 8:00 pm
I assume were talking about a dynamo here.
The voltage regulator can be adjusted to the desired ,should be in the Haynes manual.
Posted: Thu Oct 02, 2008 8:04 pm
by just_st3v3n
how ya gettin on with the project??
that oil seal ring thingy put in yet?? :wink:
steven
Posted: Thu Oct 02, 2008 8:54 pm
by GTM Coupe
You should be achieving about 14.1 - 14.5v without loading at approximate 2000 rpm. Are you running a alternator or dynamo??
Posted: Thu Oct 02, 2008 8:59 pm
by joebe1
an alternator...going to compare voltage / current rdgs with FIP on saturday but the battery is bubbling up at the moment!
Posted: Thu Oct 02, 2008 10:49 pm
by joebe1
[quote="D_3m0_n"]how ya gettin on with the project??
steven[/quote]
jason got the seals at the w end, so goin to chance it tomor, all thats left is the front window, bonnet, and interior, and a bit of a tune, took it for a spin yesterday it handles like a go kart its class
Posted: Fri Oct 03, 2008 7:37 pm
Voltage regulator is built into altenators, I thought Aidan changed that altenator. Cheak with him what he changed.Faulty regulators are not that common.
Posted: Fri Oct 03, 2008 9:20 pm
by kerryminigringo
That was a new alternator that I put in that GT Joe.What are the readings at high tickover because I checked it when I put that alternator in and it was around 14.3v which is correct.
Posted: Fri Oct 03, 2008 10:59 pm
by joebe1
well its a site, but its not big enough for a house, might change the alternator for a hamster running in a wheel :D
