Clutch problem
justcoupe
Clutch problem
Post by justcoupe »
Just after fitting straight-cut drop gears from mini sport,after fitting new clutch found that it would not work properly because the splines on the gears were not the correct profile :evil: :evil: ,3 hours work with valve grinding paste and new disc,just to get it to move freely.Beware of MINI SPORT drop gears,buy KAD!
Re: Clutch problem
What clutch disc were you using?
justcoupe
Re: Clutch problem
Post by justcoupe »
Have a new clucth kit,lever,slave+master cylinder and plunger.Its a non-verto clutch.
Re: Clutch problem
So is it a problem with the clutch disc going onto the primary gear ?
Do you have the old helical primary gear, does the clutch disc fit on it correctly ?
justcoupe
Re: Clutch problem
Post by justcoupe »
It fits on the old one about the same as the new one.Moves pretty free on it too. My head is melted with this.HOLDING UP THE BUILD :evil:
Re: Clutch problem
If the disc is free on the splines, then you need to check the pressure plate or flywheel assembly.
Any pics of it as it is now ?
justcoupe
Re: Clutch problem
Post by justcoupe »
Think I have it sorted,the bush on the top drop gear is the wrong size 2.5 mm bigger than the original bush,moving around on the shaft,cant believe I missed it. :oops:
Re: Clutch problem
Ah, the old A/A+ transfer gear roller bearing size problem. :D
justcoupe
Re: Clutch problem
Post by justcoupe »
Was given a set for a 1275cc, P+T ENGINEERING are making up a new bush for me,should be back on track soon
Re: Clutch problem
justcoupe
Re: Clutch problem
Post by justcoupe »
Got it sorted,working a treat now thank god.Thanks for all your input,it really helped! :D :D :D
