hi guys,
i replaced my rear subframe as it cracked and got new braided brake pipes got everything sorted except for being able to take the stupid rubber cone of the shock absorber strut thingy......
iv tried hitting it at the corners so it might loosen slowly and pop off... put it in a vice and hit it.... hit it off a piece off wood....
is there an easier way to get these off??
thnks
is there a secret trick...
- just_st3v3n
- just_st3v3n
Re: is there a secret trick...
got it off....
a vice and brute pushing power ( ) and it popped off, there was good bit of rust holding it together... sorted now...
Clean up the rust and remember to put some copper grease on the mating surfaces before you reassemble.
- just_st3v3n
did do, i remembered
have your bearing here too.. u in a rush with getting it? might just pop it down to you one the days...
let me kno whenever you need a hand with your mini or marcos too, i owe ya that for sure
No huge rush for the bearing,whenever you're passing.
