Guys,
By now you should have received your IMM ticket via Email. Please print it out and make sure you bring it with you, it has all your information contained in the bar code which should help towards a smoother check in.
Also make sure that you have a print out of your ferry or plane ticket.
Make sure that your passport is in date.
Get out your tent and check that it's all there , you probably haven't looked at it since the IMOC camping weekend last August. Also check your airbeds and your pump.
It's the Euro in Holland, so no problem there , but those going through the UK will need sterling for the boats, credit cards can be used but make sure they are in date and that you have your pin number.
Drivers, have a look at your cars, check that all your lights, wipers, horn, are working, check the condition of your spare wheel, check oil and water levels, tyre pressures, etc.
Have you a first aid kit, warning triangle, high viz jacket, spare bulb set?
Don't leave too late, sort them out now
fell free to add anything that you feel I may have left out.
IMM Check list
Re: IMM Check list
WELLIES!!!!!
