horible noise
horible noise
my mini has started to make a horible grinding noise from the passenger side hub and it is harder to turn than normal i have taken the breake pads out to check if there was any stones behind them and they are fine so i think it must be the bearing is this the right thing to think or not
Re: horible noise
Tim,
It certainly sounds like a bearing. Are you running wide wheels as these put extra loading on the bearings. I had a 13inch Sportspack years ago and both rear bearings went about the same time. It's a horrible grating sound alright.
- DaveC
Re: horible noise
Sounds like it could be the bearing.
- Merlin
Re: horible noise
Tim didnt you just put a big 1380 in your mini latle if so you can expect quite a bit of this kind of stuf the big motors have a handy nack of finding weak components, It sounds very much like a wheel bearing there cheep as chips but a pain in the but to replace
Re: horible noise
yes i was thinking the engine would have had somthing to do with it thanks and yes the mini has 13X7 revos on it so that probably didnt help
Users browsing this forum: No registered users and 20 guests
