Broken bolt
Posted: Wed Apr 16, 2008 10:08 pm
by 66mini
A mini owner has contacted me about the top steady arm . The mounting bolt that takes the arm itself has broken just below the surface. A mechanic had a go at it with a 3 inch nail which left the surface a bit dimpled. I have tried to get it out with a stud extractor but broke 2 of them in the progress. Access it restricted. Anyone got any ideas. Have tried the usual drilling out , heat .
Due to access it looks like an engine out or part out anyone interested in trying it ?
David
Re: Broken bolt
Posted: Thu Apr 17, 2008 1:15 am
Leave it where it is and get one of the newer engine stradies that attach to the top of the flywheel cover. Mini Spares do them I think.
Re: Broken bolt
Posted: Thu Apr 17, 2008 2:50 am
by Merlin
the other posblity is to hele coil it you can get the kit in most motorfactor the kit contains a drill bit and a hele coil and a tap you simple dril the stud with the drill them tap the hole with the provided tap then bobs your uncal.
Re: Broken bolt
Posted: Mon Apr 21, 2008 10:30 pm
You still have the problem of fitting the drill in. I currently have the same problem curtosy of TMG.
Re: Broken bolt
Posted: Mon Apr 21, 2008 11:00 pm
by Merlin
not if you have one of these
