Carburettor question
just_st3v3n
Post by just_st3v3n »
hey guys i fitted stage 1 kit a while back but got a hif 38 with it, my car is doing strange things the last few days..
eg
when driving up a slight hill ( that makes engine work harder to maintain same speed) with 2 passengers at a speed of around 80-90 km/h and accelerating to get to 100 km/h the engine starts make a weird noise and even at full throttle the engine looses its power and starts slowing down (as if there is an overload of petrol going in or something)......
strangely enough when i get up the hill the car has no problem responding to acceleration.... this only seems to appear when their are passengers in the car, and also when im doing short roadtrips (30 mins-2 hours)
i did the gaps and timing etc a while back and made sure they were spot on, i am going to check these again.. other than that i am clueless as to what is wrong??
are their any mechanics around cavan area that you can recommmed to set up carburettors properly???
the HIF 38 is a fine instrument. has this started happening only recently? was it OK a while back?
from the descriptoin it could be fuel starvation.
if your points gap checks out ok it could be dirty petrol or fuel contaminated by water/moisture.
Sounds like fuel starvation.
What needle came with it?
Remove dashpot and piston and clean with carb cleaner, refit and fill with fresh oil.
just_st3v3n
yea it has only started recently.... fuel starvation could be it.. not to sure but im doing about 220 km on 15 litres, dont know what that is to gallon but just there to give you a clue whether thats high or low...
am off work the weekend and im making a list of stuff needing to be done and am adding cleaning the dash and piston to that, will let u know more then..
i dont know what needle came with it as its second hand, is there any way to check it?
thanks for advice
I make that 41 mpg which is good if your trying to save money or bad if your trying to drive hard.
When you remove the piston the needle is secured by a single screw which when you remove it be carefull theres a small spring behind it, also cheak that the needle isn't bent. At the top of the needle there will be a 2 or 3 digit code.Tell us what it is, could be anything as these carbs where fitted on everything from a mini to a sherpa van.
