Bottom arm bushes
Bottom arm bushes
The old bushes that I removed had a metal sleeve through them where as the new ones are just plastic,is there any difference or should the new ones have had a sleeve.
Show me the mini...
Show me the mini...
- Merlin
Well tbh KMG the ones I got for Merlin was the same but I measured the old steel ones and they where well with in the tolerances so I used them I reckoned the plastic ting-me-bobs (the technical name) where just to keep the bush in shape.
Regards,
Paul.
P.S. according to the BMC manual I have + 6 tho is the tolerance.
Regards,
Paul.
- Merlin
- Merlin
