Window Problems
Window Problems
Hi, I've got a '77 clubman & of course when it rains it leaks, I sorted one of the leaks which was coming in through the master cylinder holes but the other one is in through the windscreen on the bottom left hand corner & I can't stop it from leaking anyone have a suggestions on how to sort this problem ??. Cheers
Its probably a combination of hard cracked rubber & corrosion. Even with a new shell and a new rubber you will still need sealant so don't get too upset at the prospect.
Don't use the generic "sillicone" sealant - sillicone sealant releases acetic acid during its curing stage - hence the acrid smell - this is corrosion in a tube as far as steel is concerned.
Get a purpose designed, corrosion neutral sealer, Terosan do good stuff for example, their 1KPUR is bulletproof.
