elecrtic problem
b.fitzs
elecrtic problem
Post by b.fitzs »
yet another problem.....my horn and dip light does not...i ve checked the fuses and its working fine,.....i have noticed once or twice thathorn/diplight arm has smoked once or twice before..could i have blown the circuit...i cant beep at those naughty drivers and its annoying the hell out of my... any iders anybody
Merlin
Post by Merlin »
high brian. Your most probly right, your switch unit has burned out look enuf it is real easy to replace just order one from mini spare's. Remove the steering wheel. Then with your new switch gear beside the old one chande the plugs from one to the other, screw it back down steerining wheel back on and your in buiness.
Sounds right to me.
Have you fitted air horns or spots without a relay??
Merlin
Post by Merlin »
.jes woody the exact same ting was going trough my mind haa they say great minds tink alike. Humm does that mean your mind is great and i tink i like its. (dam im confused) :D.
b.fitzs
Post by b.fitzs »
and the plot thickens and i have a cold arm....can anyone guess why??
Merlin
Post by Merlin »
what you mean brian your arm gets cold when your driving the car ?
