LIGHTS!
Flately79
LIGHTS!
Post by Flately79 »
Hi there,
Recently enough I got a "Wired by Wilson" toggle switch panel. All great and looks fab. However, now all of a sudden I am without sidelights, main beams, indicators and rear lights / brakes. I have hazards.
Electrics are not my thing so I don't know what circuits each type of light is on. I want to avoid taking off each and every lens to see if a bulb has blown too.
My first port of call will be to check to see if a connection has come loose behind the switch panel but failing that has anyone any advice on how to find out the problem without me spending hours working my way through each bulb?
Thanks in advance
Re: LIGHTS!
Were all the lights working before you fitted the new switches?
Flately79
Re: LIGHTS!
Post by Flately79 »
Hi, yes they were. I took out fuses today to check them and they were all fine and then just tried again and all are working again. Maybe the points of the fuses were a little corroded? I'm expecting them to go again anytime though...
