MTM2022 18th June 2022
1980 Clubman GT - Contact:
After 2 years it's back. MTM 2022 is running on Saturday the 18th June 2022. This year its a one day event running from North to South. Block bookings have been made with hotels close to each end of the route. Once entry forms & fees are returned accommodation details will be forwarded. This year's MTM will be back to route books.
This year the forms can be emailed back to me and also you can use PayPal at scallan.jp@gmail.com
The entry fee remains the same at €50 for members and €60 for none members.
There will be no breakdown service this year
Re: MTM2022 18th June 2022
First entries received in the post yesterday. Keep them coming.
Keep those entries coming in. The block booking of the hotel is only for another two weeks. I will be attending the AGM next Sunday. You can hand me the entry then. Thanks
Asked to repost this. Get those entries in
With just over two weeks to go for this years MTM, all participants are reminded to ensure that their car is in roadworthy condition and in good mechanical order so as to cover the 450 approx miles from Malin Head to Mizen Head and back to Bantry afterwards. Wheel bearings, ball joints, fan belts, cooling system, drive shafts, brakes, lights and all other systems on your Mini should be checked over and any faults rectified before you set off. Proper preparation of your Mini now should help to ensure you complete the event without a hitch and will also enable you to have a better experience without the stress of breakdowns. As MTM2022 is being held on public roads, it is up to each entrant to ensure that their Mini is in full compliance with the rules of the road and has proper insurance cover, tax and nct where applicable.
Below is a list of suggested items to bring with you:
1. A fully inflated spare tyre,a can of tyre weld, a jack and wheel brace.
2. Oil, Brake Fluid,a small jerry can of petrol & Water/Coolant;
3. A set of spanners. 7/16", 1/2", 9/16" will cover most things (11mm, 12mm, 13mm, 14mm if you're stuck)
4. A fan belt, head gasket and a set of points (make sure they are the right ones for your Mini)
5. A coil and a condenser(make sure they are the right ones for your Mini)
6. A bottle of good rad sealer.
7. A mobile phone/charger and a warning triangle.
8. Enough cash to pay for your accommodation, petrol, food, and drink!
9. A Sat Nav for use with the tulip diagrams.
10.A head gasket
11.A tow rope
Looking forward to it and see ye all on the 17th June
Jp Scallan
10.A head gasket
11.A tow rope
Jp Scallan
Users browsing this forum: Ahrefs [Bot] and 1 guest
