Over flow pipe
- Whats your location?: F91HY42
Ballisodare village co sligo - Region: Western
Over flow pipe
On top of fuel tank I can see a overflow where you connect a pipe ? If so where does this pipe go
Any help greatly appreciated
GM1
GM1
Re: Over flow pipe
Without that pipe, you'll get a whiff of petrol in the car. It should feed down into a hole in the floor of the boot with a grommet around the hole.
Re: Over flow pipe
Hi Billy fairplay thanks for your quick reply your spot on I'm getting a smell of petrol allrite IL get onto the job in hand
Appreciate your help tnx
G.M 1
G.M 1
Re: Over flow pipe
That breather pipe is normally hard plastic but you can use a petrol compatible rubber hose if you have to.
Re: Over flow pipe
Let the hose protrude as far as the bottom of the subframe, it needs passing air to draw the fumes away.
Re: Over flow pipe
Thankyou guys your help is much appreciated
G,M 1
G,M 1
