national mini day
national mini day
anyone heading from the general northeast region to this,would be nice to form a mini convoy to galway
- Merlin
high
high guys ill also be heading down to galway on the 1st im from newcastle south dublin maby we could meet up in tyrrell's pass cos there is a big car park + they do lovle coffe there which ill need to keep me bones together for the rest of the journy haa i aa route planed it says at an avrage speed of 100 kph the journy takes aprox 2:30 hours so in our minis give or take six haa.
regards
Paul
regards
Paul
- Merlin
- Merlin
I rang Adrian Cusack earlier in the week regarding the Mini Day. It will take place in the same venue as last year's event i.e. The Kil Cuan Centre in Clarenbridge in Co. Galway, starting from 11am.
Coming from Dublin, you come as far as Oranmore, turn left and take the Limerick road for 3 miles until you come to Clarenbridge.
Kil Cuan is located about 300 metres after the church on your left. There are big gates leading into the centre.
Hope it helps,
Hope it helps,
- Merlin
- Merlin
Speaking to Adrian the last night, there's also talk of having a get together the Saturday night before the Mini Day. Apparently entry forms are on the way so make contact with him directly if you are interested westernregion@irishminis.ie
- Merlin
- Merlin
from westernregion@irishminis.ie like billy says i will e-mail him tommrow.
- Merlin
hi ya , i got a rubber mount down in halfords..but in the meantime i use the car jack to lift and hold the exhaust in place and use some old fashion coat hanger wire to hold it in place ..did the trick to get me about..i'm gonna use the rubber mount tomorro after work i hope ..if the weather holds up...only thing is that i had to use the curb to raise it a bit..it was very awarkard to get under it....if only i had a ramp....tell me who is the best guy to go to get my mini checked over????
