1981 Mini City 1000
Re: 1981 Mini City 1000
When I was rebuilding the rear subframe I bought a proper greasing gun for the rear arm shafts. However, I heard a pop on both sides while squeezing the grease in. Anyway, those plastic inserts are useless so I bought some (expensive) stainless steel ones from Japan. I don't want to have to put 1/2 a litre of grease into each arm to ensure that grease gets to the brass bush.
The new plastic insert...split
Stainless steel replacement...
The only thing missing from the rear subframe is the hand brake cable and the quadrants for the arms. Will need to investigate some nickel zinc electroplating for this.
- colinf1
Does the larger repair piece help with heat dispersion?
Front subframe looks pretty good, nice smooth bends, done by hand or tool?
Yes the extra metal helps to pull the heat away. If the piece was the exact size it would warp really badly.
I used a cheap 15 euro pipe bending tool to make the bends. However the length of tubing came as a circular coil that I had to straighten first by hand.
In case you don't know the braided hoses are handed left and right
I did not know that woody. Thanks for the heads up. Luckily it was just a loose fit for now and I hadn’t tightened everything up because the hoses need to go into the brake calipers first before tightening the nut on the subframe.
Clean up the inside so you can get a good seal of paint on it. Doors tend to rust from the inside out. Great work your doing.
Yes agree woody. There is excellent penetration of the weld from underneath and given this inside area will get a lot of water, the flatter the area the better. I am planning on epoxying the door frame and skin before they are assembled.
I also identified the ‘sided’ braided hoses on the front subframe. Turns out I put them on the correct side. There are deeper internal threads on the drivers side.
- colinf1
Looking good, nice clean & tidy welds!
Thanks Colin. Takes quite a while to get used to the welder and finding the right settings for specific types of welds. I am going to keep going on the boot and driver's door while it's all going well.
- colinf1
Very tidy looking welds, keep it up!
