Steering column movement
Posted: Fri Aug 17, 2018 1:21 am
Hi,
Failed nct (amongst other things....) On steering wheel movement. It moves about a mm or more up and down. Its tightened to parcel where it should be. Took steering wheel off and shaft has play within the steering column itself if that makes sense.
Should this play be there? I assume not. Feels like there should be a split collar or something there? There is a gap between the tab that sticks out from the steering wheel and the plastic bit which knocks off indicators so feels like something is missing?
