stage 1 problems
Autograss steve
Whats your location?: Tipperary
stage 1 problems
Post by Autograss steve »
hiya lads have a 998 bored had a skim and valve job done and stage one fitted but now runs crap dies when revved , fitted new needle and checked ignition timing,tried adjisting mixture screw still runs crap,any ideas
Re: stage 1 problems
Bit more info needed, but sounds like a fuel problem.
What carb/air filter/compression ratio/dizzy/cam/fuel pump are you running ?
What do the plugs look like ?
Oil in dash pot?
