Gutter
- What Minis have you?: Clubman Estate
Re: Gutter
I ran a bead of PU (Polyurethane) Sealant around the gutter of my estate and spread it with my finger it over paints without issue and doesn't shrink or react to paint make sure you wear gloves (only comes off when your skin does if you let it dry) and a small bead is plenty and wipe off excess with some thinners as its tough to remove when dry if i was doing it again I would mask off either side of where you want it and just peel off masking tape before it dries for a really clean finish, its great for sealing internal seams and welds too spread it with a disposable paint brush with bristle cut short to work it into the welds / seams
