Bit of a clear out
Posted: Wed Mar 09, 2016 11:09 am
by just_st3v3n
Right was tidying up the garage and found some excess bits I don't need. Some good some not so good.
998 a series engine,was running before taken out of 74 clubman €125
Loom taken from 74 clubman €25
Selection of stuff.
7.5''grooved discs little surface rust €20
Carburetor (possibly hs4) good for parts as petrol housing is cracked FREE
998 cylinder head with rockers and valves (89 mini a+ engine) €20 needs a head skim (surface rust)
Trumpets FREE
chrome for rear pockets FREE
1/2'' spacers €5
Dash vents (need clean and paint) FREE
4 pot metro calipers (non vented disc ones) need new rubbers and a clean €70
Fiesta calipers (10 inch conversion) + hubs had started conversion but drilled holes 0.5-1mm too big on one hub. Will slide onto your own hubs when holes are drilled out to 10mm easy conversion need good clean and new rubbers €70
Old starter motor FREE
New inner corner scuttle panels €15
Boot lip repair panel €20
Gear selector €20
Also have a set of brand new boxed 8.4 discs €30
Set of 5x10 mambas with good tyres. Need good clean or new lick of paint €175
All parts located in Cavan town, first come first served might be able to get some stuff up to Dublin the weekend.
089 234 0530 , steven
Re: Bit of a clear out
Posted: Mon Apr 04, 2016 8:01 pm
by knock.mini
Im interested in a few of the bits.. Give me a ring when you can.. 087 05 72909
I can also collect
Posted: Wed Apr 27, 2016 11:42 am
by keith
I'll take those groovy disks if still available.
Posted: Thu Apr 28, 2016 4:19 pm
by Deanmini77
still got the inner scuttle panels?
Posted: Fri Apr 29, 2016 5:37 am
by just_st3v3n
Discs gone.
Still have the inner scuttle ones.
