Removing light
- Whats your location?: Cork Lad!
- What Minis have you?: 1995 Mini Sprite!
Owned a 1995 Mini Cooper! - Contact:
Removing light
Hi guys just looking for some help in how to remove the rear lights (the complete unit) does this involve removing the fuel tank? Also how do I remove the indicators?
Kev
Kev
If you can't find it....grind it!
1980 Clubman GT - Contact:
Re: Removing light
Ya you will have to take out the bolt for the fuel tank and slide it across. Then to remove the whole unit there is just four bolts to open inside the boot on each side.
Re: Removing light
Excellent thanks a million. Any idea about the side indicatorS? Also would anyone have a link to brakes i could move to when changing to 10 inch wheels?
Re: Removing light
Minispares do two kits for conversion,their own brand calipers
http://minispares.com/product/Classic/B ... 0to%20shop
or this kit with AP original spec calipers.I have used the Minispares calipers and find them good but each to their own.
Re: Removing light
I presume you mean the side indicators as the front ones are just screwed on.
With one hand under the arch pushing the indicator outward move the indicator with your other hand towards the front or rear of the car and it should come out without too much force. The wire and bulb holder simply twist out of the back of the lens.
