Temp gauge not working
- Whats your location?: Wexford
Hi all I've a temp gauge not working. I've earthed the sender wire and switched the car on and the needle moved straight up to hot so I changed the temp sender but still no joy
Any ideas???
Any ideas???
Re: Temp gauge not working
Think so yea not 100% sure
Is the fuel gauge working properly ,they share the same voltage regulator?
The test you did would sejest the sender unit was faulty so I'm just going to throw this one out there, are you definitly on the temperature sender and not the oil pressure warning switch?
The fuel gauge it working perfect not problems with that I'm not sure what you mean about the switch but there definitely a voltage sender in the block just to the right of it under the plugs that's what I changed and still no joy
You seem to have done everything right, the only thing I can think of is a bad connention at the spade at the end of the cable, thighten it up with a pliers or replace with a new one.
I'll try that mite cut the wire back have fresh wire to make a goo connection see how that goes
