Hi Folks I have a Mk 3/4 Body shell for Sale.
I Bought this shell of Neil Kavanagh 4 years ago after it was in a minor shunt in the Park. I subsequently under took a major over hall and rebuild of this shell.
all the damage was straightened out and repaired. I then completely prepared the shell.
Here is a list of modifications it has:
- Tubed arches ( the car can be run super low with out the wheels rubbing at the back)
- alloy flat boot floor fitted
- Strengthing gussets welded in on all for corners of rear floor
- Rear bins removed
- Front ended cut down and strengthened
- Bulkhead box fitted for weber
- floor modified to fit wider seat
- super strong and better angled steering mount
(there is tones more little shuttle modifications which would really need to be seen to understand)
The shell is fitted with a Roll Centre 6 point cage which has had 4 additional strengthening points added
the shell also comes with a front sub frame Mk 5 with more room for a front mounted rad
it comes with a Curley fibber glass front end but NO bonnet
it also comes with a AP race master cylinder and standard Clutch master cylinder
It is a completely sorted shell it would make and ideal project base for a fast road track day car. Or would be perfect for some one looking to get into racing/ Rallying.
I will put it up as is for 1200 euros for every thing.
If there is enough interest I will split it and sell the shell, role cage and ancillaries
THANKS FOR THE HELP ALL
Body Shell Mk3/4 Very well prepared SOLD
- Merlin
___________________________________________________________
Visit HRE website
http://www.hre.ie
or Visit our Facebook Page
http://www.facebook.com/pages/Hickey-Ra ... 2277766935
Visit HRE website
http://www.hre.ie
- purplehaze
Re: Body Shell Mk3/4 Very well prepared
I've seen this shell in person!!!! Very nice, very clean, cheap considering the work that's been done
- hughesmarkie
You have a pm sir
