original floor coating?
armo
Whats your location?: dublin
imoc member
Post by armo »
Im in the middle of striping the interior of my 84 mini all floor pans are completely original and rust free but the blavk coating is cracked and some bits missing so my plan is to remove it all clean it back to bare metal repaint and hopefully find something to replace the original coating it had . The problem is that I have no clue wat they used in the first place somone shed some light please
Kriss
Whats your location?: Kilcommon Co. Tipperary
What Minis have you?: 1988 Austin Mini
Re: original floor coating?
Post by Kriss »
It's bitumen. Something like this:
http://www.conrad.com/ce/en/product/854676/
armo
imoc member
Post by armo »
Thank you
Redned
Post by Redned »
Often Known as Sound deadening Pads !!
armo
imoc member
Post by armo »
Thanks now I just need to find it local and cheap
Redned
Post by Redned »
Any Good Motor Factors Should Stock it.
Kriss
Post by Kriss »
I seriously doubt that
armo
imoc member
Post by armo »
Phoned one of the local motor factor they have it in 500 by 500mm sheets foe 10 euro per sheet
mgb1978
Post by mgb1978 »
Or just spray it with a coat of Body Schultz.
http://www.vinnybyrne.com/body-shop/sto ... 11460.html
Scoobasteve7
Post by Scoobasteve7 »
You can get tubs of it and paint it on from Co ops also.
It's pricey enough aroun €30 a litre I think the last time I checked.
