Need Some Help
Posted: Mon Apr 13, 2015 10:50 pm
Hi need some help car won't start without choke and runs very rough.
I refreshed the engine 3 years ago when a synchro went in the gearbox, so new oil pump, water pump got some work done on the head by Paul Hickey. New clutch and changed the primary gear rear bush. I left the car at home when I went to Oz so its been sitting there a while. I'm back working on it now but just can't get it running right???
Car info:
91 1275 Cooper
HIF 44 carb. rebuilt with full kit, BFY needle, K&N cone filter
Stage 1 kit
Stage 3 head new valve springs and guides
Lucas gold coil
New battery
New Verto clutch
65D Dstributor with new cap, rotor and leads
New plugs gapped at 0.6mm
Valve clearences 0.12"
When I first tried to get it running it would start and idle but not great and trying to drive it was impossible no power at all. I have checked for vaccum leaks and adjusted the timing, tried a new carb needle (BBW) I have a colortune but wasn't getting great results with that either. So I bought a carb rebuild kit from SU carbs rebuilt the carb and tried it with both BFY & BBW needles still no change.
Its now at a stage where it won't even idle even when its warm the second I release the choke the engine dies.
I know the best place to sort this is a rolling road but I called Mcnamaras in dublin and he said he cannot do that kind of thing and I don't know anywhere else and not really keen on paying to have the car brought to a place that possibly know nothing about carbs.
Is there anything you guys can suggest? should I try borrow a working carb from somebodies car and see if the problem remains? or is there something more obvious to you guys. Sorry for the essay just trying to give as much info as I can Please help!!!
Car info:
91 1275 Cooper
Stage 1 kit
Lucas gold coil
New battery
New Verto clutch
