Hi all,
What is the 3rd light from the left on the 4 switch matrix? The left is the hazards, the next is the rear demister, 3rd is the brake servo?, 4th is the lights.
Also, should the light come on or not on it?
Brake Servo Light?
- daniel garry
Re: Brake Servo Light?
It comes on when the brake fluid is low, the switch part is to test if the light work!
- antodeco
Thanks for that! I had a fuel leak earlier which I replaced the hoses for and I noticed the cables going into the brake servo were broken. Reconnected up and pushed the button and the light came on. I wasn't sure if it was meant to or not!
