1980 Clubman Estate
Posted: Sun Feb 15, 2015 4:32 pm
Just picked up a 1980 Clubman estate to work on for the summer
No major plans for it clean the body work nice wheels and a 1275 engine and hopefully make it a daily driver if i can get some van panels ill turn it into a van and panel the inside,
Drove it home engine didn't feel great but that's fine I plan on getting a 1275 (if anyone has one for sale let me know) also the mounts and steady's will need replacing engine moves on braking and acceleration and the 1098 engine has some mayo in the rocker cover,
Electrically it'll need a bit of tidying new battery is loosing charge when off so that will need investigating bad earth hopefully and a few small bits lights and wiring,
Body wise it'll need a bit of work lifted carpet and front floor pans and a new seat cross member rubber bung was missing and caused the damage so that's the first job
The interior isn't too bad new carpet and a good clean and the rear seats may need a bit of work if i keep them in it and speedo isn't working so have a look at that too
Ill order the floor panels first and work from there
