NCT question
- mini_sprite94
- Whats your location?: just out side Mitchlestown.
- What Minis have you?: 1995 Mini Sprite, Elmo.
NCT question
hello! I'll be soon getting my Mini, and I'm switching it over to an Irish reg. car, thats means a NCT has to be booked for it too.
How does a mini do on emmisions for the NCT? are there any other real problems with a mini and the NCT?
- dayoungfella
- mini_sprite94
Thanks Marcos, how do they do that? how does that work? I'm new to minis, and cars is general, trying to find out more of the whys and hows, instead of just going "ok mr. mechanic make it go vroom vroom" I'm the nutter who'll be sitting there nodding as some sage mini nut shows me how the starter works! :D
You should get yourself a copy of the Haynes manual that covers your particular age of Mini, there have been a few editions and the older ones might not cover your model.
It has a step by step guide on maintenance and overhaul of all aspects of the Mini, from replacing a fuse to stripping an engine. You can pick them up fairly easy on ebay, should only cost a few quid.
- mini_sprite94
- dayoungfella
You may have a bit of a problem there! Converters were neccessary on all cars manufactured after 1992....
Also, your car is more than likely injection and not carb so to make sure your car is running right, you can reset the ECU....can't remember exactly how to do it but I think you just leave the battery unconnected over night and it will reset when you connect it back up!
- dayoungfella
- mini_sprite94
dublin town, Terenure, sorry oul country habit of saying that.
- mini_sprite94
- mini_sprite94
- dayoungfella
- mini_sprite94
no its cool I'm doing mine up at the moment, all these part I expected to have to get. I'm also getting new belts for it. But thats the fun of a mini!
:D
I found this site,
http://www.cats4less.co.uk/home.php
mini sport have one too
http://www.minisport.com/classic-mini-s ... oduct.html
:D
I found this site,
- mini_sprite94
