hs4 tuning
hs4 tuning
well lads, iv just fitted a stage 1 kit i got from minispares to the 998, freeflow manifold, RC40, alloy inlet and AAU needle. couldnt get the car started so started playing with the mixture a bit and got a little splutter and now i'v finally got it running, with the mixture nut down 9 full turns from the top! from all the info iv found online that seems like an awful way down!
surely this is way off??
anyone got any tips on tuning the hs4 so i can have it drive-able til i get it to someone who can set it all up properly?? would the likes of mcnamaras in dublin or westward in enfield be any use to me?
cheer lads
molly the mini
Re: hs4 tuning
Post by molly the mini »
This should do the trick for ya I use it a lot and find it very good
http://pages.ebay.com/link/?nav=item.vi ... 23&alt=web
Re: hs4 tuning
The colourtune is good for fine tuning but like you said you are way off.
Are we talking about a hot or cold engine, if its cold make sure the choke is working properly as this would do the same job as turning the mixture right up. If its a warm engine It sounds like the needle is too far down the jet, when you fitted it did you put the collar level with the bottom of the dashpot. Maybe it wasn't tight and has sliped down.
Re: hs4 tuning
have a colour tune here so thats grand but the fact i had to turn the adjusting nut so far has me a bit confused!
cold engine woody, pretty sure the needle collar hasnt slipped down but il check n get back to ye. the only thing iv done with the choke is put the cable back on the arm, was grand before so didnt alter it
Re: hs4 tuning
air leak? will need more fuel
Re: hs4 tuning
woody wrote:air leak? will need more fuel
checked a few times, no air leaks! It started up from cold and ran with choke for a couple of mins so i started winding the mixture nut in a bit and the revs picked up and now ot'l stwrt from cold at say 2 turns leaner but thats still 7 from the top!
Re: hs4 tuning
just check that when you replaced the needle it was set flush with the bottom of the piston.
Re: hs4 tuning
keith wrote:just check that when you replaced the needle it was set flush with the bottom of the piston.
took it out again and spotted a small crack on the collar so swapped it with another 1 and refitted all again and brought the adjusting nut back to the top and down 15 flats and it starts! there was a bit of petrol comming out the overflow so i swapped over the needle valve from another carb and thats solved it for now
it idles ok on choke but konks when the choke is in but sounds good to me when its running with throttle, opinions?
choke and throttle
revs with no choke
just choke
its booked in at mcnamaras for friday morning so if i can have it driveable for the trip to dublin id b happy!
Re: hs4 tuning
well its not good! collected the car friday evening, 100 quid lighter and its not running right! the only time there isnt a flat spot is above 3500 rpm with the throttle wide open! so il be calling back in on monday morning!
should the AAU needle need much profiling or more or less a direct swap and tune up??
Re: hs4 tuning
how can they charge €100 and *not* fix it??? :roll: :roll: :roll:
imho you have an air-leak,,, if you are passing, feel free to drop in. txt me first. - i fitted that exact kit a few years back.. ran like a dream. 60+mpg and nippy.
Re: hs4 tuning
Did you do any changes with the air filter?
Can you post a photo of the carb area.
Re: hs4 tuning
keith wrote:how can they charge €100 and *not* fix it??? :roll: :roll: :roll:
exactly, il be going back to em tomorrow!
funny enough me and the girlfriend are just heading to dunlaoighaire in 5 mins! would you happen to b around today or tomorrow keith?
woody wrote:Did you do any changes with the air filter?
its just a replacement K&N in the standard airbox
il get pics up in the next little while
Re: hs4 tuning
im here today.. pm sent. includes my phone number!
Re: hs4 tuning
had a good look at that today when Dan popped over.
no apparent air leak.
removed and plugged breather hose which was perished.
checked timing with vacuum disconnected - correct @6 degrees btdc
checked fuel mix with colourtune found it to be slightly lean but more importantly would not richen-up under full throttle, causing flat spot.
replaced dashpot oil with 20W/50 - still no richening-up under acceleration - damper, piston, spring, needle, jet all correct.
really looks like a fueling problem - car idles and runs ok apparently, but bogs down under load.
i would try a different dashpot damper first then maybe a different carb.
Re: hs4 tuning
cheers keith, thanks for helpin out!
been doing a bit of driving since, its slightly better than it was but still has that flat spot, going to call mcnamaras in the morning and see what they say and then start changing bits when im home tomorrow afternoon
all suggestions welcome!
Re: hs4 tuning
well i got to mcnamaras this morning and told em whats wrong and they went at the car again and tried an aav needle, it made a difference to the low down lack of power but its now acting strange in 4th! just wont pick up in 4th! the guys at mcnamaras are suggesting a carb rebuild
for some reason im feeling like i need to do a compression test on the engine!
davemk4
Whats your location?: cork
What Minis have you?: 1975 saloon MG Metro powered
Modifications: MG Metro Goodness
Re: hs4 tuning
Post by davemk4 »
The AAV is just like the AAC needle
I have the AAU with my car and it's great..
Have you got a co% meter?
The colour tune is only good at idle not good when the
Car is under load...
Have you checked your timing?
Dave
Re: hs4 tuning
davemk4 wrote:The AAV is just like the AAC needle
Dave
havnt got a co meter
the timing is at 5 or 6 degrees btdc
davemk4
Re: hs4 tuning
Post by davemk4 »
Dave
Have u the vac disconnected?
Re: hs4 tuning
Dave
it was disconnected and plugged for checking with the strobe and then all put back
davemk4
Re: hs4 tuning
Post by davemk4 »
What way r the plugs after a spin?
Re: hs4 tuning
davemk4 wrote:What way r the plugs after a spin?
il whip em out in the morning and have a look, the plugs are only 250 mile old so it'l b easy enough to see the colour of em
Re: hs4 tuning
before you go for the full carb rebuild, try the dashpot, piston & spring from another HS4
Re: hs4 tuning
keith wrote:before you go for the full carb rebuild, try the dashpot, piston & spring from another HS4
i will be! i think they were just wanting rid of the mini to be honest!
