Page 3 of 9
Re: 92 mini aka bibsi
Posted: Sun Nov 17, 2013 2:30 am
by coolmini
Woody
Actually if you want to use an 8 or 7 port with filter you have 3 choices
1 get longer grp front end or a clubby front ent
2 buy a 8 port bonnet which has a buldge
3 do what I do. Diy
When I looked around almost all have cut a hole in the bonnet to make space for fuel rail / filters.
Actually there is a 4th way but rather pointless.
you could run shorter trumpets that will loose you up to 10 hp and the same with torque. Or smaller filter again loosing about 5 hp. But that would fit under round nose.
I'm building this for power and not to win a beauty contest.
Posted: Sun Nov 17, 2013 2:40 pm
What was the problem with the air box you were making?
Posted: Sun Nov 17, 2013 5:30 pm
by coolmini
One needs 20mm clearance at the entry for the air box. By the time the filter was in with a decent bel mouth shape on I had 5 mm left to the gearbox.
Posted: Sun Nov 17, 2013 5:40 pm
Wolsley 1000 ?
Posted: Sun Nov 17, 2013 7:29 pm
by coolmini
That would have the space too but don't like the look of those at all.
Posted: Sun Nov 17, 2013 8:39 pm
by coolmini
Is the wholsey longer in the front I thought the extra length came from the boot
Posted: Mon Nov 18, 2013 9:47 am
Not longer but the bulge gives a little more space (every bit counts) . The bulge wouldn,t be as wide as yours.If you use the airbox could you not sit the original filter beside the servo.
Posted: Mon Nov 18, 2013 11:08 am
by coolmini
Not enough space there woody. Absolute minimum filter size for my application is too big so am doomed. Might just fit some bonnet spot lamps which will hide it all.
Posted: Mon Nov 18, 2013 12:12 pm
Thought about the spotlights to. A few curves will look better with the MK1 front.
Posted: Mon Nov 18, 2013 12:18 pm
by coolmini
Haven't found a spider lamp pod that would suit yet don't like the one that goes all the way across the bonnet and most of them kinda dive into the bonnet straight after. I'd need something that would be the same size as the bulge on my bonnet. If you see something by all means show me the light.
Posted: Mon Nov 18, 2013 10:40 pm
by coolmini
Right bonnet is primed and sanded. Went for dzus fasteners in the end. So welded in some plates in the corners at the front. Holes drilled into the bonnet to take the fasteners
May not be the best looking but it covers everything under the bonnet and the air filter has plenty of room to breath.
Posted: Tue Nov 19, 2013 10:33 am
by kona
You seem to have similar ideas to me except with the money to do it and a shell that's solid! That head looks sexy!
Posted: Tue Nov 19, 2013 8:53 pm
by coolmini
Hi kona,
Yes it sure costs a lot proof of which is my empty account. Lol.
Been saving for that head for ages.
She'll wasn't so solid to start with. New boot, Sills and full front end including wings all had to be replaced. Door skins were gone too.
Posted: Tue Nov 19, 2013 9:36 pm
by macker
coolmini wrote:Hi kona,
Now you know what mini stands for!
m - Money
i - Is
n - Not
i - Important
Posted: Tue Nov 19, 2013 10:48 pm
by coolmini
You know what you're right macker. What good is saving it in a bank when it goes bust much rather spend it.
Posted: Wed Nov 20, 2013 10:46 pm
by coolmini
Hmm spraying wasn't a so good idea last night the paint froze as opposed to dry and that was with the 2pack paint and winter hardener. Heater tripped the fuse so back to sanding and go again with new heater
Posted: Thu Nov 21, 2013 1:33 am
by macker
If the paint isn't dry yet when you're rubbing it back here's a tip,
Use a bar of soap!
rub the bar of soap over the area that you are rubbing and keep doing it till you're finished
(obviously that is if you are rubbing it down with rubbing paper)
Posted: Thu Nov 21, 2013 8:52 am
by coolmini
Ya lost me. What will that do. Is it the same as using soapy water and 800 wet n dry paper.
Posted: Thu Nov 21, 2013 10:12 pm
by coolmini
Right got the paint done second time round.
Bonnet done and this time heaters on and working
Some touch up on the car for the dzus fastener brackets alla DIY
Only thing is I must have had an air bubble in the gelcoat of the fiberglass
So now I have a hole in the paint
Now just have to wait and buff it all.
But the throttle bodies back in and get my wiring sorted and new fuel line in the engine bay. Make up a new throttle cable and finally get it started and retuned. Mind ye the weather is a bit dodgy to do road tuning by yourself.
Posted: Fri Nov 22, 2013 10:42 pm
by coolmini
Doesn't look half bad now that it's painted
And it's held nice n tight by the dzus fasteners.
Mind ye I would still prefer something that would look like light pods but not like the big bulky ones.
Posted: Sat Nov 23, 2013 11:11 am
Still not sure about the astetics but the quality of your work is excellent. Maybe the next monthly technical night could be a lesson in lost foam fiberglass
Posted: Sat Nov 23, 2013 8:21 pm
by coolmini
Ah sure Beauty is in the eye of the beholder lol. There ain't any meets in the west actually haven't even been to a meet yet at all at all
Posted: Sun Nov 24, 2013 11:14 am
by molly the mini
There is always a run on st Stephens day in the west if your interested if the weathers good
Posted: Sun Nov 24, 2013 11:34 am
by Billy
...and paid-up members of the IMOC will always be notified by text beforehand.
Posted: Sun Nov 24, 2013 12:54 pm
by coolmini
I am a paid member actually never got a text from the club in my live
