Moderators: spud1979 , The Marcos Graveyard , Moderators
Posts: 2244 Joined: Tue Mar 24, 2009 7:40 pm
What Minis have you?: 1995 Mini Mayfair 1994 Mini Sprite
Post
by StanO'Toole » Wed Jun 01, 2011 12:34 am
scotty_1987 wrote: did you spray the arches green?
That I did, just done them in the shed the other day... I dropped one of them and broke the end off and before I sprayed them I was using "back to black" and I didn't clean them properly and it reacted with the paint so I may buy a new set and spray them again!
Posts: 479 Joined: Mon Jan 19, 2009 8:35 pm
Post
by StevenR » Wed Jun 01, 2011 9:29 am
I had a spare set of standard arches here somewhere Stan, if i come across them in the next few days you can have them.
Post
by StanO'Toole » Wed Jun 01, 2011 10:07 am
Thank you very much Ste... I'l throw ya' a few quid.
Give me a text if you do find them, 0858178803
scotty_1987
Posts: 329 Joined: Thu Jul 01, 2010 7:57 pm
Post
by scotty_1987 » Wed Jun 01, 2011 11:32 am
ah well im sure ya will get that sorted in no time man,good luck with it anyways!:)
does it need much bodywork doin?
lcopperworth
Posts: 11 Joined: Mon May 30, 2011 3:01 pm
Whats your location?: Oxford, England
Post
by lcopperworth » Wed Jun 01, 2011 1:06 pm
That is so wimdu, really great man. You should be proud of yourself!
All generalizations are false, including this one.
Post
by StanO'Toole » Wed Jun 01, 2011 4:30 pm
Cooper-1275
Posts: 95 Joined: Mon Jan 18, 2010 8:18 pm
Post
by Cooper-1275 » Wed Jun 01, 2011 11:02 pm
You sure do have it lookin well Stan...can I have it back now please
Post
by StanO'Toole » Thu Jun 02, 2011 12:59 am
scotty_1987 wrote: does it need much bodywork doin?
There are a few bubbles starting at the front end... I'l get them sorted after Mondello and Mosney!
Cooper-1275 wrote: You sure do have it lookin well Stan...can I have it back now please
Mmmmmm.............. NO!
scotty_1987
Post
by scotty_1987 » Thu Jun 02, 2011 2:56 pm
haa
alright stan keep up the good work anyway man!
Post
by StanO'Toole » Mon Jun 06, 2011 4:10 pm
Posts: 2118 Joined: Tue Jul 18, 2006 11:15 pm
Post
by keith » Mon Jun 06, 2011 4:13 pm
very cool
Post
by StanO'Toole » Fri Jun 10, 2011 3:19 pm
Posts: 1076 Joined: Fri Oct 23, 2009 8:59 pm
Post
by CLUBMANGT » Fri Jun 10, 2011 4:31 pm
Stan I may be corrected, but I think thats a rare manifold.
Post
by StanO'Toole » Fri Jun 10, 2011 4:37 pm
CLUBMANGT wrote: but I think thats a rare manifold.
Really?
Posts: 1515 Joined: Mon Sep 14, 2009 8:34 pm
Whats your location?: knockbine tullycanna ballymitty co. wexford.
What Minis have you?: 1972 pick up 1979 leyland 88 designer
Post
by Kenneth Murphy » Sat Jun 11, 2011 12:29 am
isn'tit a cooper one??
FOUNDER OF HILLBILLY ENGINEERING .................................
FROM THIS TO THIS
Post
by keith » Sat Jun 11, 2011 8:41 am
looks like a cast 3 to 1 manifold.. pretty rare, was cooper item iirc.
i think the carb you already have fitted (HIF-44?) is better in my opinion than the one you show there (HS4), plus yours is likely to have the correct needle for your car. - that exhaust will be *noisy*
was there any other stuff in that car? where is the breakers? rare to see mini's in a breakers these days.
Posts: 2837 Joined: Mon Feb 07, 2005 11:55 pm
What Minis have you?: Traveller Turbo Hornet Equinox MINI Clubman
Post
by woody » Sat Jun 11, 2011 12:53 pm
Manifold is Cooper or 1300GT , I think the carb is HS6 but as Keith says stick with the HIF44. If there off the silver car in the scrappy hope you got the center binnical and clocks.
Posts: 1532 Joined: Sun Feb 06, 2005 10:52 pm
Post
by DaveC » Sat Jun 11, 2011 11:09 pm
woody wrote: Manifold is Cooper or 1300GT , I think the carb is HS6 but as Keith says stick with the HIF44. If there off the silver car in the scrappy hope you got the center binnical and clocks.
If he didn't he will be back tomorrow for them
Post
by StanO'Toole » Sun Jun 12, 2011 2:10 pm
woody wrote: If there off the silver car in the scrappy hope you got the center binnical and clocks.
Out in the shed in bubble warp
Tryed to put the manifold on yesterday and it wouldn't fit as it was hitting out the fuel pump? I'm guessing its just for a 1ltr?
Post
by woody » Sun Jun 12, 2011 3:53 pm
Not for 1ltr , the cooper and 1300GT both had electric fuel pumps. I took a photo of a manifolld I have you can see how close it is to the fuel pump blank plate on the engine. the second pic is the later Cooper freeflow manifold which is shaped to allow for the pump.
I'm not sure but I think some old mechanical pumps might have had both pipes on the same side.
Post
by StanO'Toole » Sun Jun 12, 2011 10:42 pm
So will that manifold not go onto on 1ltr of any sort?
Post
by keith » Mon Jun 13, 2011 11:13 am
it will go onto *any* A series that does not use the mechanical pump on the block, as woody's pic shows, the pump location blanked off.
Post
by woody » Mon Jun 13, 2011 4:43 pm
Did you check out the engine that manifold came off. 998 or 1275? Could be a nice head on it.
Post
by keith » Mon Jun 13, 2011 6:00 pm
if the engine number starts with 9F, its mine!
Post
by woody » Mon Jun 13, 2011 9:08 pm
12G would be nice too.
Users browsing this forum: Ahrefs [Bot] and 2 guests
