metro engine
Re: metro engine
Clockwise will richen the mixture.
here is a list of needles, carbs and cars:
http://www.minimania.com/web/DisplayID/ ... ticleV.cfm
here's more good stuff:
http://www.theminiforum.co.uk/forums/in ... pic=114176
you will find more info using Google....
- What Minis have you?: mini city
- Modifications: metro engine
Re: metro engine
got the needle out (finally) and its a BDR which on that site keith showed me says it is suitable for a 1380 so maybe thats why shes running so rich thanks for that keith!!
Everyday is a mini Adventure
Re: metro engine
the diff. needle does *NOT* explain how the idle is so poor. like i mentioned earlier, *any* needle can be made idle.... if you look at the graph below (thanks to the good guys at http://www.minitylamb.co.uk)
the diference between the two needles is not great until you get up to high acceleration or high revs. the idle/cruise part of the needle, typically the first 1/3 is very nearly the same, in fact the BDR is a tad leaner in parts. to me it does *NOT* explain those high readings at the NCT.
Re: metro engine
im pretty sure the jet and the small bimetallic gizmo is knackered?? apparently they get worn out after 55000 miles or so? ive ordered a BDP needle (minisport recommendation) and repair kit for it and ill borrow a gas analyzer and set it up properly!! i hope i haven't wasted money though???
the reading from the NCT were taken at 700 rpm!!
Re: metro engine
not heard of that before.... *but* im new to HIF's.rhys mate wrote:im pretty sure the jet and the small bimetallic gizmo is knackered?? apparently they get worn out after 55000 miles or so?
i'd have borrowed the analyser and set it up first, then decided if i needed to replace stuff. but, still cheaper than splashing out for a new carb!rhys mate wrote:ive ordered a BDP needle (minisport recommendation) and repair kit for it and ill borrow a gas analyzer and set it up properly!! i hope i haven't wasted money though??? the reading from the NCT were taken at 700 rpm!!
Re: metro engine
i live that mintylanb site it brilliant haha!! one thing thats worrying is it says the BDP needle is richer?? nightmare!!
Re: metro engine
AFAIR the reading is taken at idle for your car... like you said,.. @ 700rpm.. *any* needle will do at that speed. all the ones we talked about will get u through at idle.
Re: metro engine
ok cool thanks i mill for the help well appreciated!! bloody mini's haha!! wish i had a HS carb!! ill try get my hands on an analyzer and see what i can do to get it right and swap needles to see how i get on!! cheers keith!!
