Page 6 of 7
Re: 1275GTi conversion
Posted: Mon Apr 09, 2012 8:58 pm
by kerryminigringo
Posted: Mon Apr 09, 2012 9:27 pm
by keith
looking good!
Posted: Mon Apr 09, 2012 11:06 pm
by DaveC
Keep up the good work
Posted: Mon Apr 09, 2012 11:48 pm
Machine the boss with the same pattern as proper Spectrum wheels.
Posted: Tue Apr 10, 2012 12:00 pm
by Tony Cooney
LIKE
Tony.
Posted: Thu Apr 19, 2012 4:56 pm
by spicooper
Looking good i really like the colour.
Posted: Wed May 02, 2012 2:56 pm
by nearlythere
Well done Aidan, shes gorgeous. I was in Stans recently and I saw the Van, your some man!
Posted: Sun May 20, 2012 7:44 pm
by zakgt
aidan,
Well how did it run on mtm?
Posted: Sun May 20, 2012 8:14 pm
by Billy
I drove it up the road today. It's bonkers once you change into 2nd.
Posted: Sun May 20, 2012 8:40 pm
by purplehaze
Video please. Gorgeous mini mate. Love the wheels. Well impressed with the build. Fair play. Enjoy every moment in it. But. Hurry up with a video
Posted: Sun Jun 10, 2012 10:39 pm
by zakgt
Aidan,
I take back my concerns about the colour , much nicer in real life.
Posted: Wed Jun 13, 2012 11:55 am
by maxi
Absolutely LOVE the split rims Aidan. They finish it off beautifully.
On the wheel centre, how about a black centre with... giz a sec
Posted: Wed Jun 13, 2012 12:02 pm
maxi wrote:Absolutely LOVE the split rims Aidan. They finish it off beautifully.
Awaits photoshop response
Posted: Wed Jun 13, 2012 12:14 pm
by maxi
rally quickly done, but how about a little raised vinyl badge in black similar to the boot badge.
(or even the boot badge logo on its own, small in the middle)
or an embossed one out of metal if your feeling extra blingy...
Posted: Wed Jun 13, 2012 6:19 pm
by kerryminigringo
I like the green on black on.Maybe you should think of taking up this designing stuff as a job Maxi
By the way,I met the guy who originally built Benny at Mosney,he was asking how was it?
Posted: Wed Jun 13, 2012 8:42 pm
by maxi
kerryminigringo wrote:By the way,I met the guy who originally built Benny at Mosney,he was asking how was it?
Really? Wow. I hope you lied through your teeth and told him he's on his 7th MTM and been to the Nürburgring at least twice
Posted: Sun Jun 24, 2012 6:31 pm
by keith
maxi wrote:rally quickly done, but how about a little raised vinyl badge in black similar to the boot badge.
or an embossed one out of metal if your feeling extra blingy...]
imho black & green
Posted: Wed Feb 12, 2014 10:44 am
by pump101
Hi there im doing this conversion myself.. I have a 1395cc tuned gti engine buy have not got a gear box as of yet. Do you know if a 1ltr or 1.3l will fit or suit with gear ratios. I will be running 12in wheels by the way. I can get a gti box but its bout 3 times the price of the others.
Sorry if I dragged up a thread from the dead. Iv read this bout 5 times front to back and seemed like a logical place to get a reply. I probably will u have a few more questions if thats ok.
thanks in advance
Ian Murphy
Posted: Thu Feb 13, 2014 5:57 pm
by kerryminigringo
You would be better off getting a 1.3 GLS gearbox as the 1 lt does not fit straight on.The GLS gearbox has better ratios than the GTi which is a close ratio box and is more suited to the Mini.The GTi box has stronger internals but from talking to guys on the 16v Mini Forum the GLS box is more than capable from the lighter Mini.Scroll down through this link and you will see the difference in the 1lt box and the 1.3
http://www.teamswift.net/viewtopic.php?f=9&t=37943
Posted: Thu Feb 13, 2014 6:22 pm
by pump101
Thats great thanks.. I can get a 1.3 for 110e so thats a few pound saved. Are you running a hydraulic clutch on your conversion? Is there any pitfalls I should be aware of? Thanks for your quick reply.
Posted: Thu Feb 13, 2014 7:30 pm
by garshero
Beautiful car
Posted: Thu Feb 13, 2014 8:02 pm
by CB_Phil
Handsome car man, black wheel center i reckon
Posted: Thu Feb 13, 2014 8:54 pm
by kerryminigringo
I am using a hydro clutch with a Mini slave cylinder. I would recommend shortening the inlet manifold by 27mm and putting a slight cant in the engine to avoid cutting the bulkhead otherwise that would mean not being able to use the Mini brake and clutch master cylinders and that was the single biggest headache I had with mine. Also put a lot of thought into the alternator bracket as it is an on going issue with mine and vibration.. Get onto
http://www.16vminiclub.com/ and browse some of the on going projects for ideas.I will be starting another build thread in the next couple of weeks when I start work on my Clubman Estate and put the lessons I learned from the first one into the next.Where are you sourcing the GLS gearbox as I found it hard enough to get one.
Posted: Thu Feb 13, 2014 10:06 pm
by pump101
The engine is running gxr throttle bodies so I think il be ok with bulkhead clearence.
My local scrap man had one, well he said its from a 1300 swift , am I right in assuming its a glx? What are you doing for a subframe on the estate? Im going to try tackle one my self.
Posted: Fri Feb 21, 2014 8:19 pm
by kerryminigringo
I bought a subframe from a guy in Sweden but this time I will be making my own. Not sure about the GLX but if it is from a 1300 it should fit.I will be starting a build thread in the next couple of weeks.
