Garage
Garage
Am looking for garage to put mini in,want one 11 foot deep and 10 foot wide, did any body ever get one made this size.I have looked at a few places but they only want to do standard sizes.Need double doors on it 6 foot wide hanging from left side of front as you face it.
11' x 10' - enough to store 2 Minis side by side!
Tom, I've done a bit of checking on these as well and apparently they work in sheet widths i.e. 3 foot or 1 metre, you'd want to check. So the typical sizes would be 12',15',18' etc. It's when you start slicing sheets to get different sizes, it causes extra work for the manufacturer.
What I ended up doing for a 10'x10' garage extension was to get RSJs (girders) set in concrete and a frame welded up. The guy who did it for me then cut the end sheets to size with an angle grinder.
Call over to me sometime if you want to see.
- pick up man
- pick up man
Before you pour concrete, have you considered putting in a pit and lighting for it? There's pros and cons of a pit but one of the cons is dropping a leadlamp and igniting petrol fumes. Very Nasty if it happens. Ideally you should build in stairs for quick exit.
Also there's a great readymade pit supplied by a UK company called Mechmate. You'd see it advertised in Practical Classics or just google mechmate.
Hope it helps,
Hope it helps,
- pick up man
on the subject of a pit.... wouldnt be hard to install a vent fan, ducted to the bottom, from say a an old computer or an extractor unit to operate when the pit lights were on...
a sheet of steel makes a good lid. its also heavy enough so that the little people cant open it until they are old enough to be careful.
Re: Garage
There is several free ads looking for free removal of sheds!
- pick up man
Re: Garage
Finally got te garage up. I'll post a few pictures. At last the strip down of the pick up can begin
http://www.pmcsecurity.com
Re: Garage
Still have not got one must make more of an effort over next few weeks.Plenty of work ahead of you so.
Re: Garage
I,ve cut the concrete slab along the garage last week to get ready for digging the foundation this weekend and weather permitting I will get it dug over the Easter weekend and get the foundation poured after the Easter break.Only drawback from this is no mini work being done.
- Whats your location?: limerick
- What Minis have you?: 1992 cooper spi
Re: Garage
im building a gazebo for mine
Re: Garage
I just spent the last two weekends working in a gazabo, can't wait to get the garage built.
Re: Garage
I dug out the foundations for the extension to the garage over the Easter weekend and I poured the foundations the following Monday.The blockwork is finished and I,m hoping the chippie will get the roof on before the weekend.The size of it is 20ft by 17ft so should fit a few minis in there.I gave up trying to get anything done on the RSP or the van due to lack of space on the garage so when this is water tight I,ll get cracking on the projects again.I will post pics tomorrow.
- DaveC
Re: Garage
That sounds like good work.
I see the van made MiniWorld!
Re: Garage
Heres a picture of work to date.
I brought the estate out of storage to do a few jobs to it,including new rear shoes and a rear cyclinder,two new rear shocks,two drive shaft seals and a service to get it ready for the IMM.
Re: Garage
And another one,hope to have the roof finished next week and get the inside plastered so that I can put the floor down.It is big enough to store two projects and two road going cars.
