rear seat belts
DoyleL
rear seat belts
Post by DoyleL »
can any ine tell me if its possible to fit over the shoulder seat belts to a 88 city as opposed to the lap belts :D
Check on the C-pillar and see if you can feel the fitting plate behind the trim panel.
DoyleL
rear seat belts
Post by DoyleL »
thanks for that...had a feel felt the plates under the trim. Found a drilled hole too. are they difficult or expensive to install.
nope, they are simply bolt in, from what I remember the belts come with a few different brackets and bolts, check in the boot to see if the lap belt retaining nuts are already welded in situ at the base of the seat back.
These guys do rear belts for Minis:
http://www.securon.co.uk/
Users browsing this forum: No registered users and 22 guests
