Leccy fan
Leccy fan
Should the electric fan blow or suck air through the radiator.
![](https://irishminis.ie/shared/images/forum/socialmediashare.gif)
- BlackSe7en
- mini_sprite94
- Whats your location?: just out side Mitchlestown.
- What Minis have you?: 1995 Mini Sprite, Elmo.
- Merlin
Bleve it or not they auctly are ment to blow trough the rad twards the block the taught is that if the car was doing speed and the fan needed to come on to cool the engine then it would not be able to blow hot air into the oncoming ram air as you drive along no u and I all know that the fan rarle if ever comes on wile you drive but thats Rover for you.
regards,
Paul.
regards,
Paul.
