Has anyone fitted or knows of a mini fitted with coil springs instead of rubber cones.
A friend like the idea of a mini but back problems stops her from owning one, will this help or does anyone know of another solution to soften the ride . Intended being fitted to a 1995 approx car
springs
Hi 66mini,
I have the smootha ride kit fitted, Minisport.com do 2 types (sportpack and non sportpack), the suspension is fully adjustable, and the ride is alot smoother, its great, you need a special compression tool if you fit it yourself, I can recommend a good mini expert besed in the SE if needed.
Mark.
Mark.
Mark Walsh
