1977 mini
Wizard
1977 mini
Post by Wizard »
Hi all
So I aquired my 77 mini 1000 last year and it's gone through a lot of work. It was sitting in a garage since about 1990. Passanger side sill and Door was butchered....lift used In wrong position and went through both. Both floor pans needed replacement....only at the heel. Rear subframe was shot as was boot and bonnet. Both waist ralis on the rear side windows and top of rear quarter panel on passanger side. Front panel also needed changing. So have a lot of that work done myself. So I needed parts and lucky enough I snapped up a 94 1275 mini for parts. Took rear subframe, engine, front hubs and passanger door for mine.
So onto the other parts.
Rear Subframe cleaned and all new parts
Trailing arms rebuilt and pins replaced
New wheel cylinders and shoes
Front subframe also cleaned and painted
New CV boots
7.5 inch discs and new calipers
All new ball joints
New pin kits
Have 10 inch reverse style wheels
Took the 1275 engine Out and decided to use it instead of the 1000.
So full gearbox strip down and rebuild with new baulk rings and new bearings. In the block it's getting new big end and main bearings, fast road cam, new followers, vernier timing chain. Head work done so double valve springs and new retainers, bronze valve guides, stainless valves, harder seats and 3D cut, skim to get 10:1 compression ratio. All head work done by HREs Paul hickey. Also got flywheel and clutch balanced.
So that's as much as I can think of for now but I'll keep it posted
Wizard
Re: 1977 mini
Post by Wizard »
More pics
Re: 1977 mini
Looks like an interesting project, plenty of work ahead.
ctwomey
Re: 1977 mini
Post by ctwomey »
Wizard wrote: Mon Jan 10, 2022 12:50 pm So I aquired my 77 mini 1000 last year
Best of luck with the project. There are a couple of active projects ongoing at the moment on the forum. Nice to see a third underway.
colinf1
Whats your location?: Dundalk
Re: 1977 mini
Post by colinf1 »
Looks like a good job being done!
Are you doing all the work outside on your drive?
Say it will be fun moving that rotisserie on the gravel lol
Re: 1977 mini
Great to see another 70s Mini being restored. Good luck with the project. Keep us updated.
Wizard
Re: 1977 mini
Post by Wizard »
colinf1 wrote: Tue Jan 11, 2022 1:07 pm Looks like a good job being done!
It was moved over there and didn't move lol. But it's off it now ready for the subframes to be installed
Wizard
Re: 1977 mini
Post by Wizard »
Off the frame ready for subframes
Re: 1977 mini
Is the front grille fixed? It will restrict access to the distributor.
Wizard
Re: 1977 mini
Post by Wizard »
It is fixed indeed........I'm going with electric dizzy so it's not gonna have points to adjust and maintain
