mini cooper s 2000 overheating
- Whats your location?: Cork
- What Minis have you?: Classic Mini Cooper s 2000 reg
Bmw Mini cooper 2008 - Modifications: none
After a period of storage i have started using my mini Cooper S Again 00 G 23
After a short while the expansion tank starts bubbling .
i have checked the following
thermostat replaced
new coolant
Head Gasket oil clear no evidence of a damaged or blown gasket
fan cutting it at temperature but not colling it down sufficiently
any ideas what next ?
Terry
thermostat replaced
new coolant
Terry
Re: mini cooper s 2000 overheating
As the car has been sitting up the first thing to check is that the stat is opening.
MPi engines run a normal temperature around 100 deg. C so it is important that the cooling system holds pressure as water boils at a higher temperature under pressure. Is there any steam coming out. MPi expansion bottles are known to crack where the hoses join the tank.
Terry,
What thermostat are you using? Mpi's run hotter than carb Minis. I had overheating problems with my old 98 mpi but it was a common problem with a sensor which was activating the fan. There was a factory upgrade which cured it. The other possibility is that your 20-year-old rad has silted up.
Woody beat me to it.
The other known issue is the quality of the expansion tank tops. As Woody says, the system needs to be pressurised to work properly.
Thanks guys
rad checked and ok
upgraded stat and its working
no evidence of blown gasket
the hunt goes on .
hope ye are all well during these terrible times
Terry
rad checked and ok
the hunt goes on .
Terry
- Whats your location?: Derry
- Region: Northern
- What Minis have you?: 2000 Rover Cooper Sport
2006 R52 Cooper S John Cooper Works - Contact:
Try replacing the coolant header tank cap, I replaced mine with one from a 2006 Mini Cooper S.
Instantly stopped any heating issues on my 2000 Sportspack
thanks guys im taking a few days off this week and will get stuck in to it
Check the cooling fan speed. It may be cutting in OK but may not be turning fast enough. I had this problem with one turned out to be bad earth to fan. 9
DOUGAL
- Whats your location?: Glenageary, Co. Dublin.Ireland
- What Minis have you?: 2000 Cooper Sport
I had a problem with overheating on my 2000 Cooper Sport, the coolant was flowing through the rad but not being cooled , a new rad solved the problem but I tried everything else before replacing the rad.
