91 mini city
91 mini city
Hi all!
Finally got my hands on a mini! I've been looking for about a year and happy to finally find one I'm happy with! Needs some work with new door skins if not doors too (as u can see in pic) and boot lid. Also small touch around windscreen and little bit at one of the a panels that hopefully isn't too bad....! Sounds bad but the shell is actually really good. Best I'd seen in quite a while looking so hopefully all works out . Thanks for all the help here. I originally put up a wanted add and there was loads of support and advice and offer of help which is great. Loads of help and positive comments in a post I made a few weeks ago when tying to get it towed too so thanks all! Seems like a great group and forum and look forward to meeting ye at an event etc! Should be a fun project! First step is to buy a mig... After I clean the Garage! :-/
Michael
Michael
Re: 91 mini city
Good luck with the project, Michael. Be sure to start a project thread in the Projects section of the forum. If for no other reason, it helps you keep a record of progress.
Re: 91 mini city
Billy wrote:Good luck with the project, Michael. Be sure to start a project thread in the Projects section of the forum. If for no other reason, it helps you keep a record of progress.
Thanks Billy, must do alright. People might have good advice when they see things I'm doing!
- Region: Northern
Re: 91 mini city
That will look great when it's restored.Billy wrote:Good luck with the project, Michael. Be sure to start a project thread in the Projects section of the forum. If for no other reason, it helps you keep a record of progress.
Re: 91 mini city
Cheers, thanks Ger. Must start a project thread. Took one of the doors off today to get a better idea of the rust...!LorenzoGer wrote:That will look great when it's restored.
- Whats your location?: Belfast
- Region: Northern
Re: 91 mini city
Nowadays these cars are hard to find. Earlier I also owned a mini but I lost it in an accident. This was the first car of mine.minimike wrote: ↑Mon May 08, 2017 11:34 pm Hi all!
Finally got my hands on a mini! I've been looking for about a year and happy to finally one I'm happy with! Needs some work with new door skins if not doors too (as u can see in pic) and boot lid. Also small touch around windscreen and phenq where to buy little bit at one of the a panels that hopefully isn't too bad....! Sounds bad but the shell is actually really good. Best I'd seen in quite a while looking so hopefully all works out . Thanks for all the help here. I originally put up a wanted add and there was loads of support and advice and offer of help which is great. Loads of help and positive comments in a post I made a few weeks ago when tying to get it towed too so thanks all! Seems like a great group and forum and look forward to meeting ye at an event etc! Should be a fun project! First step is to buy a mig... After I clean the Garage! :-/
Michael
